Civil 3D Forum
Civil 3D Gate symbol along alignment
2 REPLIES 2
1051 Views, 2 Replies
I am using a Civil 3D corridor to represent a site perimeter fence in 3D, the model will also be used for 2D plans. I use the corridor alignment for the 2d plan representation, fence linestyle etc. I have created a dynamic block representing the the standard gate (bowtie) symbol, is there a way to associate this block with the alignment so it appears at nominated chainages?
2 REPLIES 2
Citadel2012
You could create a "dummy" design profile that had grade breaks at the specific locations along the alignment that you have gates, then use a grade break alignment label style linked to that profile with the dynamic block as the marker. However, changing the locations of these gates would not be dynamic and would require you to change the "dummy" profile grade breaks.
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
HorizontalCurveGuy
create an alignment label style: edit a major or minor style to insert your block at a given interval. this method will be good for set locations
I would suggest a line/curve lable style then you have the freedom to slide it along where ever it is needed
Rail Community
