Civil 3D Forum
Civil 3D - Fixed Spiral between fixed tangent and fixed curve
3 REPLIES 3
Spirals
481 Views, 3 Replies
Hi there,
I'm trying to recreate an existing alignment using Civil 3d 2012, however I can't get the right spiral.
The sequence is tangent + spiral+ curve. They are all fixed and I have the points where the spiral starts and ends.
Thanks.
Tags (1)
3 REPLIES 3
Alfred.NESWADBA
in reply to: Spirals
All fixed might result in curves with none tangential break points.
What are the values you have and maybe a drawing-upload for us to see what you got/what you tried ... might help
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Spirals
in reply to: Alfred.NESWADBA
Hello Alfred,
As you mention, indeed the spirals I get are not tangent so I wonder if it
can be done in a different way.
Attached a jpg of my geometry.
Thanking you.
S.
Alfred.NESWADBA
No, if the current specifications are that hard/that exact with start-point, end-point, radius/K/... values then I guess the specs are wrong.
If you have the chance for using some tolerances then you might use other construction types like floating curves/spirals to come as close as possible to the specs.
- alfred -
Alfred NESWADBA
Rail Community
