Civil 3D Forum
Civil 3D dont respond command plot
2 REPLIES 2
jorge.cervantes
370 Views, 2 Replies
Hello everyone
I have a problem that when you send the print command to the computer do not select the window this only happens when I select "What to plot-Window".
Select or point to point and the window makes the same problem
You can not get out of that command at the bottom are all commands that are executed, you need to click about 5 times a scape key to get out, this problem is recurrent in 5 computers.
Annex nfo files and displays the image in civil.
2 REPLIES 2
Amigo,
start over with a local drawing, for instance one of the sample DWG in the Support folder.
If it plots normally, it means you have a network problem...
jmayo-EE
in reply to: jorge.cervantes
I think the, 'has a command in progress" means your session of C3D is no longer functioning correctly.Try restarting C3D and use Recover to open the file.
John Mayo
Rail Community
