Civil 3D Forum
Civil 3D Developers : SuperElevationData and Objet Model
4 REPLIES 4
rubenarias
302 Views, 4 Replies
Hi there,
I'm a newcomer in this forum, and I'm not sure if my question is in the right place. English is not my mother tongue, so I apologize in advance.
I work as a engineering tools developer, and some of my clients use Civil 3D. My work consists on developing extra tools, in order to expand the capabilities of Civil 3D according to client needs.
So I'm interested on having a good understanding of the Object Model.
My problem is that I can't use the SuperElevationData object, for Civil 3D 2013. According to Object Model, http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/civil_om_civil.htm SuperElevatioData is a member of the Alignment object, as usual in previous version (at least in Civil 3D 2008, 2009 and 2010)
On the one hand it seems to be disappeared from the libraries, but on the other hand it is possible calculating superelevation as a standard user.
And what is more, all of the objects, that depend on SuperElevationData, have disappeared.
Does anyone know what happened to the SuperElevationData object in Civil 3D 2013?.
Thanks in advance
Rubén Arias Fernández
PhD. Civil Engineer
4 REPLIES 4
Jeff_M
in reply to: rubenarias
Yes, it has migrated to the .NET API. THis is one reason that we have been told to quit using lisp for customizing C3D....more and more things will be exposed in .NET only.
Jeff_M, also a frequent Swamper
rubenarias
in reply to: Jeff_M
Thank you very much Jeff,
I'll start developing with .NET
PhD. Civil Engineer
AllenJessup
Welcome to the forums. Jeff's already answered your question. I just wanted to point out that there is an AutoCAD Civil 3D Customization forum that you might like to participate in.
Allen Jessup
Allen Jessup
CAD Manager - Designer
rubenarias
in reply to: AllenJessup
Thank you Allen,
I will follow your advice.
PhD. Civil Engineer
Rail Community
