Active Member
byanez
Message 1 of 2 (384 Views)
Civil 3D Coordinate Systems
384 Views, 1 Replies
11-06-2012 08:21 AM
Greetings,
If I set up my Civil 3D drawing in some known coordinate system, e.g. State Plane, in the "drawing settings", can I then toggle my drawing into other known systems, e.g. UTM, by changing the coordinate system under "drawing settings"?
If not, how are the coordinate settings used?
AllenJessup
Message 2 of 2 (381 Views)
Re: Civil 3D Coordinate Systems
11-06-2012 08:32 AM in reply to: byanez
No, You can't toggle them. The coordinate system is set so that if you're brining in data from another coordinate system that Civil recognizes there may be a possibility that the data can be transformed. The coordinate systems are also used when doing a Map Query or attaching FDO. Unfortunately those don't work with Civil Objects.
Allen
