Something interesting that I tried this week.
I have a Surface Pro 2, i5 Processor with 4 GB RAM and a Docking Station.
I installed Civil 3D 2015 on the system. I attached a secondary monitor using the docking station. I was able to run C3D fairly well for an i5 with only 4 GB.
I used the surface screen for the ribbon and prospector and the main screen to display the model.
I was able to interface with the pen and mouse fairly well. Sometimes using the pen to input directly into the ribbon. The SP2 pen is a watcomm and I think it works well for this type of interface. The SP2 has a small screen, so I think the SP3 would be even better.
I was able to move the window freely between the SP2 and the main monitor and even did some tracing of a raster image using the pen. Which was very cool.
It was an interesting experiment.
I would be interested to see if anyone has tried this on a SP3 say with an i7, 8GB RAM.
Check out the laptop specs in my signature 😉
i5, 4GB, Intel HD5000 graphics. I think the Surface Pro 3 has HD4400 graphics.
Once they start fitting quad core chips and dedicated video into these smaller systems, I'll be even happier.
My choice was based solely on portability. I do training and demo's all over, and only break out the big guns when I need to. (I also have an HP elitebook).
Hello! Can you tell me more about:
"Rockin' Civil 3D 2015 on a 13-inch MacBook Air | Intel i5 | 4GB RAM | 128GB SSD | Intel HD5000"
I've been debating a macbook pro and surface pro 3... Do you run this with paralells or fusion?
I don't use Cad everyday just to do small things and to review drawings of consultants...
Do you think I can function on either the macbook pro or surface pro 3?
Thanks in advace for your insight!
Mychal
The Mac Book Air is a well built machine. However it does not have a touch screen.
I have been using the Surface Pro with a docking station and second monitor. I have it set up so that Civil 3d menus are diplayed on the Surface Pro. I do this so that I can get some touch capabilities. Working with Mouse, Keyboard, Pen and finger has opened a whole new method for me... it has increased my productivity at least 15%... Again this is all in way of utilizing touch where it works best, and since Autodesk products are not touch designed... yet.. the menus are really the only part that i find benifit from touch.
I run Windows using bootcamp, so the hard drive is partitioned into 2, and I boot directly to Windows.
The MacBook Air an MacBook Pro both have better video (HD5000, HD5100) than the Surface Pro 3(HD4600), but none are using a dedicated video card.
The MacBook Pro 15" has an option for an NVIDEA dedicated 2GB graphics card, but totals $2499.
I paid $850 and use it mostly to do checks and programming. When I need to insert 30 PDF's into a DWG, I go to my HP Elitebook.
Mychal,
I think you'd be fine doing most task with Civil 3D on the MBP 15" with NVIDIA card. In fact, a lot of the guys at Autodesk I know use them to run Infraworks.
I chose the bootcamp route in stead of parallels. I let it partition the drive (which isn't very big) allowing me a dual boot option. I just think it is speedier.
I just bought a Surface Pro 3 i5 with 8GB ram and 256GB hard drive. Installed Civil 3D 2014 SP2 and it seems to be working great. Will be installing 2015 as well soon. Very pleased with the performance thus far.
Steve Hill
Civil Designer / .NET Developer
AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn
Please select the Accept this solution button if my post solves your issue or answers your question.
