Caddhead here. Long-time reader, first time writer.
I just cannot get over this glitch that interrupts my workflow. I am plowing through a CADD exercise, falling behind schedule, but finding a rhythm with the trackball and keyboard. My practice is to mouse with the right hand, keyboard with the left. I am a convert from the days of Softdesk and LDD. The autocomplete feature threw me for a loop when I first started, but one Civil 3D pro already pointed out to me that the autocomplete feature can be set on a delay to avoid banging out the wrong command in a hurry.
We are, however, scratching our heads over Civil 3D 2015's sudden non-responsive to keyboard commands. As I am heating up the keyboard with a flurry of commands and shortcuts, the keyboard is suddenly, inexplicably non-responsive. Nothing shows up on the command line when I type. I tap, nothing. I repetitively hammer letter and number keys and still nothing. The keyboard commands are not working. The design process fails, and I forget what I am doing.
Typically with two tabs open, I switch over to the next tab, and then back again. Keyboard responsiveness returns, and after I remember what I am doing, then I continue until the next cyberfreeze.
Anyone else encountered this phenonmenon and broke through it with a different work-around? Any input would be appreciated. Thanks!
Caddhead
I know what you are talking about. I have been using the same technique.
With only one file open, I just select NEW tab and go back to original tab.
Sorry,
Bill
....Civil 3D 2015's sudden non-responsive to keyboard commands. As I am heating up the keyboard with a flurry of commands and shortcuts, the keyboard is suddenly, inexplicably non-responsive. Nothing shows up on the command line when I type. I tap, nothing. I repetitively hammer letter and number keys and still nothing. ....
"Don't force it - get a bigger hammer"
As I am heating up the keyboard with a flurry of commands and shortcuts.... : Great begining to a thriller.
I have nothing to offer regarding 2015, but if the flurry of commands is coincident with an autosave, that ImHO will bog things down
Caddhead,
"...heating up the keyboard with a flurry of commands and shortcuts..."
That sure conjures a picture.
Dave
Dave Stoll
Las Vegas, Nevada
Thank you for the input. It just happened 6x this morning. Funny thing, is that when the keyboard stopped working. I switched from the non-responsive tab to a new tab, and then when I switched back again, I could see the keys I had typed in. Whether ghost commands or time warp, I am spooked.
I've noticed that when the problem happens, the commands are registering in another open drawing (at least for me). Only workaround I've found is to only have one drawing open at a time (or keep switching between tabs every time it malfunctions). What a pain!!
I have found cause of the problem but not the solution. It is Autosave. I was having the exact same issue, then it would go away when i tabbed back to the current drawing. Then, later when I would switch to the other drawing to work on it, it seemed to already have commands typed it. Bingo. What is happening is that after EVERY autosave, the keyboard commands are acting on one of the other tabbed drawings, instead of the current. Unfortunately, I have not found a fix, other than what you said, tab to another drawing then back. I increased the time between autosaves to avoid undue aggravation, and am trying to remember to hard save more often. Note that this does not happen after a hard save, only autosave. I know autodesk hates when we call their "features" bugs, but I can't for the life of me think why this would be programmed in on purpose.
you can also turn off the tab display. I've found that to work for me. I got used to the tabs but prefer working without them if it means a smooth working environment.
I have the same issue described here, but I do not have autosave turned on. I'm pretty sure that I do have multiple drawings open when it happens.
AUTODESK.... This should be a top priority for the next hotfix release... I'm the Digital Technoloy Chair for the ASLA and I've been getting peppered with questions about this same issue!
This is progressively getting worse!!!! Nothing worse than nunchuking a drawing and suddenly realize half the commands you've typed in haven't appeared... Switching to another tab only further takes your brain out of the drafting you were in the middle of!
PLEASE FIX THIS ASAP.
John Mayo
John Mayo
Also the obvious, make sure someone hasn't tripped over the cord and partially unplugged it or one of your keys hasn't broken.
I watched one co worker hammer on a keyboard with a broken space bar, then went to the closet & dug him out a new one.
I have heard IT can often fix 90% of problems with "Is it plugged in? Is it turned on?"
Joe Bouza
Thanks for directing our collective frustration to the appropriate Autodesk department. Though I am glad to know I am not the only user experiencing this odd quirk of the Civil 3D 2015 tab feature, I am still not certain it's a software bug. Better to request that software engineers investigate the issue.
