Using C3D 2015, SP1.
Has anyone seen this in profile view? Same Structure right next to each other, the one on the left is correct the one on the right looks as though the floor is at the rim of structure. See attached.
I can chage the Sump Depth to 1.1 then it changes back the way its suppose to be, be it though now it has a sump. Not what I want.
Very weird, I don't think this is suppose to be a new feature! Can anyone shed some light?
Solved by Jay_B. Go to Solution.
Yes this is a known issue in 2015 which Autodesk is aware of, see This thread .
This usually means you do not have enough cover over the pipe. If you lower your pipe the structure will look correct.
