Active Member
ArcticWolfie
Message 1 of 5 (88 Views)
Civil 3D 2015 Point cloud only showing 1 point
88 Views, 4 Replies
08-12-2014 12:11 AM
I've been searching on the internet now and then but I don't know what I'm doing wrong. I try to import this (78GB) PTS scan into Civil 3D but it only shows 1 point out of 60 million points... and I have no idea how to display more points, whenever I try to create a surface it says that it will export 1 point to the surface.
Does somebody got any idea what I'm doing wrong?
I attached a screenshot.
I figured it out... :smileyfrustrated:
It seems the pount cloud source was in US decimals and my system is set to NL decimals... so all values are multiplied by 1000, which probably makes the point cloud too spread out and it starts excluding points. Changed my system to US decimals and reimported the pount cloud and everything is working fine.
autoMick
Message 2 of 5 (78 Views)
Re: Civil 3D 2015 Point cloud only showing 1 point
08-12-2014 01:28 AM in reply to: ArcticWolfie
Is it the point cloud density slider setting?
Infrastructure Design Suite Premium 2015 SP1
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000 (and another with GTX680)
Active Member
ArcticWolfie
Message 3 of 5 (67 Views)
08-12-2014 02:18 AM in reply to: autoMick
No I tried that, and it's around 50% so... around 30 million points.
autoMick
Message 4 of 5 (51 Views)
08-12-2014 04:51 AM in reply to: ArcticWolfie
How about POINTCLOUDPOINTMAX ?
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/E...
Cheers
- Mick
Active Member
ArcticWolfie
Message 5 of 5 (48 Views)
08-12-2014 05:04 AM in reply to: autoMick
