in 2014 had box in lower left corner that displayed distance and angle during command and coords
anyway to get this in 2015?
Solved by DMFACER. Go to Solution.
It is on the left side of those icons on the bottom right.
I am used to the left bottom as well.
Bill
Click on the icon in the lower right of the screen (3 stacked horizontal bars). This will open the settings for the status bar. There should be a check mark next to Coordinates (first one listed). If not, simply click on Coordinates and it will turn them on in the status bar.
thanks...how about displaying distance and angle...say like during line comand
Mine does that by default when I'm in the command, but if your's is not, you may have to right-click on the coordinates panel during the command, and change the settings from the shortcut menu. I believe you're looking for it to be set to Relative, but you may need to look at the other settings to get what you need.
