Distinguished Contributor
millermccoy
Message 1 of 7 (394 Views)
Civil 3D 2015 display coords, distance and angle
394 Views, 6 Replies
05-21-2014 09:47 AM
in 2014 had box in lower left corner that displayed distance and angle during command and coords
anyway to get this in 2015?
2015 Civil 3D
Mine does that by default when I'm in the command, but if your's is not, you may have to right-click on the coordinates panel during the command, and change the settings from the shortcut menu.  I believe you're looking for it to be set to Relative, but you may need to look at the other settings to get what you need.
wfberry
Message 2 of 7 (390 Views)
Re: Civil 3D 2015 display coords, distance and angle
05-21-2014 09:55 AM in reply to: millermccoy
It is on the left side of those icons on the bottom right.
I am used to the left bottom as well.
Bill
millermccoy
Message 3 of 7 (377 Views)
05-21-2014 10:30 AM in reply to: wfberry
don't see it anywhere
2015 Civil 3D
Valued Contributor
DMFACER
Message 4 of 7 (369 Views)
05-21-2014 11:02 AM in reply to: millermccoy
Click on the icon in the lower right of the screen (3 stacked horizontal bars).  This will open the settings for the status bar.  There should be a check mark next to Coordinates (first one listed).  If not, simply click on Coordinates and it will turn them on in the status bar.
"The most dangerous phrase in the language is 'We've always done it this way.'" - Rear Admiral Grace Hopper
millermccoy
Message 5 of 7 (341 Views)
05-21-2014 11:22 AM in reply to: DMFACER
thanks...how about displaying distance and angle...say like during line comand
2015 Civil 3D
Valued Contributor
DMFACER
Message 6 of 7 (336 Views)
05-21-2014 11:26 AM in reply to: millermccoy
millermccoy
Message 7 of 7 (330 Views)
05-21-2014 11:43 AM in reply to: DMFACER
perfect!
2015 Civil 3D
