Civil 3D Forum
Civil 3D 2015 Already Showing Signs
13 REPLIES 13
Message 1 of 14
ToddRogers-WPM
1584 Views, 13 Replies
So I installed C3D 2015 this morning and MAPOPTIONS will not display a dialog box.
CMDDIA = 1
FILEDIA =1
I also tried -MAPOPTIONS, +MAPOPTIONS and .MAPOPTIONS.
I even went to the CUI and there is nothing out of the ordinary.
I also went to the Planning and Analysis workspace and selected Map Options from the ribbon.
NOTHING WORKS!
Todd Rogers
13 REPLIES 13
Message 2 of 14
answered >>>here<<< (hopefully useful 😉 )
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 14
Message 4 of 14
Cadguru42
in reply to: ToddRogers-WPM
How do basic issues like this get past Autodesk on release? And what's even more sad is how bad the English is on the knowledge base article that gives the workaround.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 5 of 14
Jeff_M
in reply to: Cadguru42
FWIW, my install went smoothly and the correct paths were added. I have seen no problems at all...yet.
Message 6 of 14
neilyj666
They are too busy with Cloud/360 nonsense which looks good in the glossy brochures and presentations
BTW the author of the workaround is a native French speaker (I have spoken to him in the past and I think he is French and based in Switzerland) but he got the solution posted pretty quickly if you follow the link posted by Alfred above
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 14
GTVic
in reply to: neilyj666
I had this problem with the release candidate and also for the one web-installed from the Civil 3D 2015 Product Trial web page. The full download version has just arrived so I haven't tried that one yet.
The solution works although you don't need to restart, just open a different drawing or start a new drawing to trigger the LISP/MNL reloading.
That support file search path is long.
Message 8 of 14
Jeff_M
in reply to: Jeff_M
I take that back, the path noted in the fix above was in fact missing. I misread the paths I did have.
Message 9 of 14
GTVic
in reply to: Jeff_M
I think they had an issue in 2012 where some of the paths in the shipping product were actually invalid folder names. So this has been an issue before.
Time test with "C:\Program Files\...\UserDataCache" as the "Start in" folder (and "My Documents" folder being a network share):
Civil 3D 2013 start time: 35 seconds, Options dialog: 3 seconds
Civil 3D 2015 start time: 35 seconds, Options dialog: 3 seconds
Time test with valid writeable C: drive location as the "Start in" folder:
Civil 3D 2013 start time: 9 seconds, Options dialog: instantaneous
Civil 3D 2015 start time: 12 seconds, Options dialog: instantaneous
Message 10 of 14
GTVic
in reply to: GTVic
Other things I've found:
Trusted Location C:\Program Files\Common Files\Autodesk Shared\Extensions 2015 seems to be invalid
ACADVER reports 20 instead of the expected 19.2
Message 11 of 14
Alfred.NESWADBA
in reply to: GTVic
All AutoCAD 2015 based products have the internal release number 20.0, so that is correct.
- alfred -
Alfred NESWADBA
Message 12 of 14
GTVic
in reply to: GTVic
After my install the following folder doesn't seem to have the correct permissions. Depending on how you copy a survey database into the folder, you may not have write access to the file.
Survey Folder:
C:\ProgramData\Autodesk\C3D 2015\enu\Survey (has no "Everyone" group with full access)
Tool Catalogs folder:
C:\ProgramData\Autodesk\C3D 2015\enu\Tool Catalogs (has an "Everyone" group with full access)
Message 13 of 14
AllenJessup
in reply to: GTVic
Good catch. It's bad practice to rely on the Everyone group for permissions. Many IT Depts - like ours - automatically disable that group on all networked computers.
Allen
Allen Jessup
CAD Manager - Designer
Message 14 of 14
GTVic
in reply to: AllenJessup
We've had that issue also, we had to get permission to make folders under "C:\ProgramData\" writeable to solve application errors.
I see there is not much consistency under C:\ProgramData\Autodesk for security permissions for various folders and releases.
Microsoft designed C:\ProgramData as a location for common data and yet it is hard to get to and locked down so tightly by IT departments. PITA.
C:\ProgramData\Autodesk includes read/execute/special permissions for "Users". The special permissions include all 4 create/write permissions but those 4 don't propogate to the actual files. For my computer I've decided to give the Local Users group write access to C:\ProgramData\Autodesk\C3D 201x\ and everything underneath. Now the Figure Prefix databases are editable!
Rail Community
