I've just installed the SP2 for Civils 3D 2104
My issue is that the command line prompts, while within a command is missing.
I dont use dynamic input, but even with this turned on, it does not show all the command options that should be available.
Can anyone tell me the command / option to turn it back on?
I can't find it for looking.
Solved by david.zavislan. Go to Solution.
Dan,
Can you post a drawing? Or a screen grab of the command line in the middle of a command?
Dave
Dave Stoll
Las Vegas, Nevada
https://www.dropbox.com/s/bf4n0kkzmli095f/screenshot_Civil3D2104_SP2.jpg
no in-command options show up since I did the SP2 update.
This is my normal CAD 2014
https://www.dropbox.com/s/ix551v7u0lum3r6/screenshot_CAD2104.jpg
with the in-command options visible.
thanks
Could try a Reset of User Settings but this does remove any customization you might have and sets things to an OOTB state for CUI etc.
Check the NOMUTT variable. It should be set to 0.
David,
I'd never heard of that one before. Kudo for you!
Dave
Dave Stoll
Las Vegas, Nevada
