Civil 3D Forum
Civil 3D 2014 S.P. 1.0 - Bug ? Material calculation
38 REPLIES 38
Message 1 of 39
wedzisi
3300 Views, 38 Replies
Hello , we found some  mistake after ubgrading civil 3d to service pack 1.0 , in coridro section shows only one side material left or right and in table and in material list report is calculated only half section , also in sholder included only sholder material , plzz see screanshot for beter understanding
38 REPLIES 38
Message 21 of 39
garrett_wynne
in reply to: michael
Sure, plus we have base structures that have superelevated properties differing from the paving.  Makes for fun modeling, but a wreck in quantities when you get only one side.
Basically, if C3D cannot give proper quantities why am I still using this?
Message 22 of 39
fcernst
in reply to: wedzisi
This was the first thing I wanted to test in 2015... It appears to be working again now in 2015 below with symmetrical Curb material being produced:
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 23 of 39
nikoue
in reply to: fcernst
i have check a project in 2015 and still find the material issue
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
Message 24 of 39
fcernst
in reply to: nikoue
Really? What specifically?
I also checked Pave for 2 - 12" symmetrical lanes, it gave the correct areas.
Then I made one of those lanes 20' wide and kept the other at 12', and the total area updated correctly.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 25 of 39
nikoue
i take only the half areas that i take from civil 3d 2013 which gives the correct results
Message 26 of 39
fcernst
in reply to: nikoue
Interesting. Can you share that Corridor?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 27 of 39
nikoue
in reply to: garrett_wynne
ok
https://copy.com/G2nyTOZMKgBP4Rcb
Message 28 of 39
Hello, wedsizi.
I see you made section view like i want to have. Please, can you send me that cross section in cad form. I use civil 2011.
Regards.
Message 29 of 39
fcernst
in reply to: nikoue
Getting this issue....
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 30 of 39
nikoue
I have use custom subassemblies. Load them into civil 3d after close and restart civil 3d and you will resolve that problem.
Message 31 of 39
fcernst
You are modeling the road using two Baselines for the centerline, and half-road assemblies.
When I make a Full assembly out of your two half assemblies, and use one Baseline for centerline, it works (red solid hatch are the two Materials I chose).
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 32 of 39
nikoue
Can you send me back the model with one baseline?
But if it works with one baseline it’s not a solution.
If you open the same model with two baselines with civil 3d 2013 and rebuilt the corridor, the materials are correct.
And it’s easier for me in such a project to work with two or more baselines.
As models became complex more baseline needed to handle them.
Message 33 of 39
fcernst
in reply to: nikoue
We can agree to disagree on that.... This road model would be a lot easier to deal with by using one assembly with targets.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 34 of 39
nikoue
OK but the fact is that with two baseline the program dont work correct.
Civil 3d 2013 and 2014 without sp1 have not this problem.
Message 35 of 39
fcernst
in reply to: nikoue
Yes, I can confirm that for 2013 now. I don't want to uninstall SP1 on 2014 to test this though.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 36 of 39
nikoue
its a known issue for 2014 sp1.
I don't understand how autodesk people think.
Its a huge bug
Message 37 of 39
pault34
Thought maybe, why fix previous versions when 2015 is out for download. Anyone check 2015 corridor behavior? I haven't searched for 2015 bugs just yet.
Message 38 of 39
vcoleman
in reply to: pault34
Is this going to be fixed.  Any idea what to do until they fix this problem besides upgrading to civil 3d 2015.
Message 39 of 39
Jay_B
in reply to: vcoleman
FYI,
This issue has been resolved with the release of 2014 Service Pack 2.
Readme file
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
