Hello , we found some mistake after ubgrading civil 3d to service pack 1.0 , in coridro section shows only one side material left or right and in table and in material list report is calculated only half section , also in sholder included only sholder material , plzz see screanshot for beter understanding
Solved by Jay_B. Go to Solution.
upss Sorry 🙂 i fix it ,
reinstal of civil 3d without service pack its works , i thinck it is problem with ubdate
I too have this problem.(Only recognizing materials on the right side) My drawing is too big to attach.
I have installed the update as well.
Any thoughts?
I can confirm this error, just tested it with one of the Tutorial drawings.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
This is definately not solved!!!!!
same issue here ...volume calulations on only half the section!
I spend more time chasing my tail with this program then I do on production.
If your asking about the Material Volumes issue, no it has not been addressed yet AFAIK.
Thank you. Running numbers for a good stretch of interstate, and just realized I only have half a quantity of my structures.
This problem has been ongoing for five months. Isnt one of C3D main function to compute earthwork quantities acurately? This is crazy not to be a top priority for autodesk to fix. Can we not get a hot fix?????
I don't know about a Hot Fix. The release of 2015 is imminent and they have addressed some of the volume computation issues. The one I know specifically about is the software will now calculate volume based on 3D area (their words) instead of 2D footprint area.
As far as marked as solved. As Matt mentioned. There is still discussion of what qualifies a post as solved. The marked as solved function is to point users searching for a solution to their problem to a potential solution not to indicate an issue has been addressed by Autodesk. In this case the workaround was probably viewed as something that would solve that one issue and allow a user to continue working on their project. It never had anything to do with it being "solved" by Autodesk.
Allen
Allen Jessup
CAD Manager - Designer
I'm still trying to find the workaround....
A very simple length x width x depth / 27 is not compatible for most jobs we build.
