Civil 3D Forum
Civil 3D 2014 S.P. 1.0 - Bug ? Material calculation
38 REPLIES 38
Message 1 of 39
wedzisi
3180 Views, 38 Replies
Hello , we found some  mistake after ubgrading civil 3d to service pack 1.0 , in coridro section shows only one side material left or right and in table and in material list report is calculated only half section , also in sholder included only sholder material , plzz see screanshot for beter understanding
38 REPLIES 38
Message 2 of 39
Jay_B
in reply to: wedzisi
Nothing attached.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 39
wedzisi
upss Sorry 🙂 i fix it ,
reinstal of civil 3d without service pack  its works , i thinck it is problem with ubdate
Message 4 of 39
ejfancett
in reply to: Jay_B
I too have this problem.(Only recognizing materials on the right side)  My drawing is too big to attach.
I have installed the update as well.
Any thoughts?
Message 5 of 39
sboon
in reply to: ejfancett
I can confirm this error, just tested it with one of the Tutorial drawings.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 6 of 39
Joe-Bouza
in reply to: sboon
What did SP1 fix? Would it be wise to detach from my deployment? I want to roll out this week. Currently the deploy has it appended
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 7 of 39
sboon
in reply to: Joe-Bouza
The list of fixes is available here.  I'd guess that the most important one for most people was the display problem in the Corridor Section editor.
Steve
Steve
Message 8 of 39
Jay_B
I converted a large streets project as a test last Friday from 2012 to 2014 SP1 and at the time didn't think anything of my Curb Material Shapes missing from left side of Section Views, but upon further review, I am also missing the entire left side (material shapes) for every corridor. Material Volume Table only quantifies half the Assembly as previously mentioned.
In this case no big deal because it's already been constructed (and in all my testing last week) this is one of the biggest glitches I've seen so far with SP1 but there have been a handful.
If your on subscription and haven't already done so I'd recommend filing a Support Request for this issue and referencing this thread.
We just started our upgrade as we were awaiting the SP1 release, hopefully this issue get's fixed soon as we need to use Material Volumes on an upcoming project and hope not to have to revert to HF1.
C3D 2018.1
C3D 2016 SP4
Message 9 of 39
wedzisi
in reply to: Jay_B
ok SP fixes mot bugs but then Damages  enother ? 🙂 must be fixed soon as posible 🙂
Message 10 of 39
pault34
wedzisi, This is tagged as solved, was that by an autodesk moderator? Doesn't seem like it is... a reinstall without sp1 doens't seem like a fix?? The last comment was posted back in Oct. 10th 2013, has anyone noticed and other major bugs??
Message 11 of 39
rnicoll
This is definately not solved!!!!!
same issue here ...volume calulations on only half the section!
I spend more time chasing my tail with this program then I do on production.
Message 12 of 39
mathewkol
It's "solved" from the perspective of this thread, a.k.a. There is a workaround. The software defect itself has not been solved.
The jury is out whether to mark these discussions as solved when there is a workaround vs when the defect has been fixed
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 13 of 39
nikoue
in reply to: mathewkol
There is also an error in the "publish selected layouts" command. I have made section Views witch has earthwork tables attached. I create layouts using section sheets. The layouts is ok. If i plot a single layout everything is ok. But if i use the "publish selected sheets" command, to plot all my sections at once and create a pdf , then the tables for section 1 is plot in section 3 and the same error affect all sections. I don't know how its happens. If i open the drawing with civil 3d 2013 then the publish command works ok.
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
Message 14 of 39
garrett_wynne
in reply to: nikoue
Has this been addressed by Autodesk?  I too am having the same issue....
Message 15 of 39
Jay_B
in reply to: garrett_wynne
If your asking about the Material Volumes issue, no it has not been addressed yet AFAIK.
C3D 2018.1
C3D 2016 SP4
Message 16 of 39
garrett_wynne
in reply to: Jay_B
Thank you.  Running numbers for a good stretch of interstate, and just realized I only have half a quantity of my structures.
Message 17 of 39
michael
This problem has been ongoing for five months.  Isnt one of C3D main function to compute earthwork quantities acurately?  This is crazy not to be a top priority for autodesk to fix. Can we not get a hot fix?????
Message 18 of 39
AllenJessup
in reply to: michael
I don't know about a Hot Fix. The release of 2015 is imminent and they have addressed some of the volume computation issues. The one I know specifically about is the software will now calculate volume based on 3D area (their words) instead of 2D footprint area.
As far as marked as solved. As Matt mentioned. There is still discussion of what qualifies a post as solved. The marked as solved function is to point users searching for a solution to their problem to a potential solution not to indicate an issue has been addressed by Autodesk. In this case the workaround was probably viewed as something that would solve that one issue and allow a user to continue working on their project. It never had anything to do with it being "solved" by Autodesk.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 19 of 39
garrett_wynne
in reply to: AllenJessup
I'm still trying to find the workaround....
A very simple length x width x depth / 27 is not compatible for most jobs we build.
Message 20 of 39
michael
Yeah same here.
Almost every project we have requires shoulder widening to allow for guardrails at bridge ends.
Rail Community
