Hai
My civil 3D exporting option does not showing the option of export to dwg. any one can help (image attached)
what you mean by using save as ? i want civil 3d objects as dwg file
Perhaps the dropdown menu: File -> Export -> Export to AutoCad -> (Pick you poison!).
Bill
BTW, I think most of us have determined that the SAVEAS is not a good option for sending to an older version.
What, specifically, are your intentions? Converting Civil3D objects to vanilla AutoCAD objects? Trying to save down to an earlier version of Civil3D?
Thanks sir,
but how can i get back my export option from let upper corner "A"
if it is possible to export a specific part from Civil 3D, same like "w block" in autocad?
As Jeff said, do a repair. Google "Repair of Autocad Installation" for instructions. Should take about 15 minutes.
Bill
2013 has this same issue on my system. I hardly use 2013 but when I need to Export to dwg from 2013 I've just been using the command EXPORTTOAUTOCADxxxx where xxxx is the dwg version to be exported to.
The command still functions normally but it is missing the icon on the Application Menu.
I just opened my Civil 3d 2014 program and see the same problem--the option to export to DWG has suddenly disappeared. I tried a repair but it didn't fix the problem.
Did you find a fix for this issue?
Thanks.
No, I never did but it's working in 2014 SP2 here.
Do you have SP2 installed?
