Civil 3D Forum
Civil 3D 2014 Hotfix #1 installed, but "Product Update" message won't go away
5 REPLIES 5
murray-clack
431 Views, 5 Replies
After sucessfully installing the Civil 3D 2014 Hotfix #1, I still get a message on the Product Update menu saying that a Product Update is available (even after I reboot)
When I try installing it again, I get a message saying that my system is up to date, but the "product update available" message won't go away
5 REPLIES 5
Neilw_05
in reply to: murray-clack
I'm having the same issue. I've filed a support request and will post the reply.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
wfberry
in reply to: Neilw_05
Just for the record, it appears that I have it installed and have experienced no problem.
Bill
Neilw_05
Here is the reply from support:
I think I'll leave mine running as it is not really a bother and it might be handly for other notifications.
At this   point, to get the Communication Center to leave you alone, you will need to   disable it. There are 2 ways to do this:
1. Change   the name of the executable WSCommCntr4.exe found here:   C:\Autodesk\Autodesk_IDSU_2013_English_64bit\x64\C3D\Program Files\Common   Files\Common Files (64-bit) Folder\Autodesk Shared\WSCommCntr4\lib Rename it   to _WSCommCntr4.exe [this will need to be done when C3D is not running.
2. You   can follow the steps outlined in this article using the CAD Manager Control   Utility: http://beingcivil.typepad.com/my_weblog/2012/07/how-to-disable-communication-center.html
The first   option is certainly easier, and can easily be undone if you desire to turn it   back on in the future.
Please   let me know which you choose, and the results.
WIN 10 64 PRO
troma
Is that the same as InfoCenter?
Here's an easy way to turn that off:
http://otb.manusoft.com/2013/04/turning-off-infocenter-in-autocad-2014.htm?utm_source=feedburner&utm...
Mark Green
Working on Civil 3D in Canada
troma
in reply to: troma
Yes, it is, according to the actual download page:
http://www.manusoft.com/software/freebies/misc.html
Mark Green
Rail Community
