AutoCAD Civil 3D General Discussion
Valued Contributor
0 Kudos
Post 1 of 10
Civil 3D 2014 EXTREME time lags with plotting to PDF,
280 Views, 9 Replies
05-09-2014 11:44 AM
Sorry to hi-jack this thread but I can not find a way to ask my own question (even though I am logged in). Anyway - We are running AutoCAD Civil 3D 2014 SP#1. This morning I had no problem plotting to the PDF option (or publishing 60 pages to PDF files) but this afternoon it keeps going not responding. Exactly the same drawing and layout tabs, 5 seconds this morning and 45 minutes this afternoon for a single layout tab plot. I have done several hard reboots with no change. Windows 7 on Dell Optiplex980 computers. We just upgraded to 2014 in the office here, 4 computers all now running 2014, essentially identical computers. All seem to be running into EXTREME time lags with plotting to PDF, but not every time. Is there a setting that we may need to change? Does anyone have a thought that might help? We are getting very frustrated! Thanks in advance!
Split and Edited by
Discussion_Admin
Glen W. Cameron, C.E.T.
Engineering Technician 1
City of North Bay
North Bay, Ontario, Canada
*Expert Elite*
176 Kudos
Post 2 of 10
Re: Civil 3D 2014 EXTREME time lags with plotting to PDF,
05-09-2014 05:50 PM in reply to: glen.cameron
Are you logged into to the website?
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given. Such messages will be deleted unread & without a reply.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
*Expert Elite*
76 Kudos
Post 3 of 10
05-11-2014 08:11 AM in reply to: glen.cameron
What are you using to create your PDF files?  Adobe?  DWGtoPDF (that comes with Autodesk products).  I use the latter with better results. If you're using Adobe, perhaps there's an update waiting for your approval to install.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
*Expert Elite*
463 Kudos
Post 4 of 10
05-11-2014 02:11 PM in reply to: glen.cameron
Also check your Acad Profile, if your system should be looking to a network location for Plotting files.
Options>Files Tab>Printer Configuration Search Path>
Plot Styles
Plotters
PMP Files (Printer Calibration Files?)
Are these all set to your organizations location?
We've been seeing quite a few Profiles reset themselves to default, not sure exactly why but might have something
to do with Launching Civil 3D to quickly after cpu startup and network drives not being active & ready when C3d is
looking for it's supporting files. Never had this issue prior to 2014 here.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Valued Contributor
0 Kudos
Post 5 of 10
05-12-2014 04:56 AM in reply to: LisaPohlmeyer
I always use the "DWGtoPDF" option. Thanks,
City of North Bay
Valued Contributor
0 Kudos
Post 6 of 10
05-20-2014 04:40 AM in reply to: Jay_B
No luck - everything looks correct and the same as it has always been. It may be the drawing. Other drawings do print as expected. About 50% of the drawings do not plot correctly (time lag), but the others seem to be normal. I have run the Audit command but it found nothing wrong. Still stumped...
City of North Bay
Distinguished Contributor
5 Kudos
Post 7 of 10
05-20-2014 05:02 AM in reply to: glen.cameron
Couple things I've seen slow it down in the past (although not to the extent you are describing) but it might help.
Uncheck Maintain Visual Fidelity in your Options. This (apparently) only comes into play when saving drawings down to an earlier version so there is no reason for it to be checked on.
Do you have any view DVIEWed? Had one project for whatever reason when the views were twisted they took forever to do anything. Just as a test we "untwisted" the views, and everything behaved normal.
Go into the Custom Properties for the .pc3 and bump the resolution down and quality "slider". We've had that help a ton when plotting to PDF, and the results are barely noticeable from the higher resolutions.
Good luck. I feel your pain.
Valued Contributor
0 Kudos
Post 8 of 10
05-20-2014 08:49 AM in reply to: tmullins
Thank you for your thoughts. This particular drawing has 70 layout tabs each containing a single viewport with appropriate zoom ratio. Not much else to report other than standard draghting entities with annotative symbols and text all set to the same scale of 1:1 all sitting over an Xref'ed master drawing. What gets me is that it worked fine for several years, and then one afternoon it simply started acting up. Nothing new was done to the drawing as only the Xref is updated. And the master drawing is fine so it should Xref in just fine as well. Hmmm....
City of North Bay
1 Kudo
Post 9 of 10
05-20-2014 10:52 AM in reply to: glen.cameron
Not sure it'll help but I know I cannot use the publish in background option without terrible lag. Worth a shot
Valued Contributor
0 Kudos
Post 10 of 10
05-20-2014 11:50 AM in reply to: jkier
I too have found that the Publish in Background does not work in most cases, or takes so long that I have to leave it over night for a few simple pages. I have also tried publishing without doing it in the background and it took 6 hours to do the 64 layout tabs. Normally the 64 pages would take less than 30 minutes to publish them to PDF in the foreground. Thanks for the comments!
City of North Bay
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
