UNKNOWN COMMAND "MAPCONNECT". I am in planing and Analysis. Actually no commands work .
Solved by vcoleman. Go to Solution.
It works on our system. We just upgraded to C3D-2014. Maybe a bad install?
It works here in 2014 and has always worked in previous versions. Start with restarting the program. If that doesn't work. Reboot the computer.
If neither of those works you can check if the Planninganalysis Partial CUI is attached.
After that I'd suggest a repair. If none of that works. You may have to reinstall the program.
Allen Jessup
Allen Jessup
CAD Manager - Designer
Good work. Mine is set to 3 so that's why I didn't notice. Thanks for posting the answer.
Allen
Allen Jessup
