Autodesk AutoCAD Civil 3D 2014 contains a bug involving rebuilds on surfaces displayed in customized colour schemes, colour books and even the hard-copied standard colour schemes. Surface rebuilds work OK if the surface is displayed as triangles or contours but it does not work if the surface consists of Levels/ Elevations, unlike in previous versions of Civil 3D.
CIVIL 3D 2013
For a terrain surface constructed from a Point File, it is possible in Civil 3D 2013 to use the “range interval” option to provide colour banding of surface elevations over and above those 6-10 colours available in the “red, green, hydro” etc. colour schemes. By manually clicking on the “colour scheme” property in the “Surface Properties- Analysis” dialogue box, the colour can be changed to any colour available in Index Colour, True Colour, or in Colour Books, up to a maximum of 200 colour bands.
If the Points File used to construct the terrain surface later requires editing, such as to remove data spikes, and the Rebuild function is used under “Prospector/Surface/ right click on Rebuild”, the surface displayed as colour banded Elevations/ Levels changes correctly to conform to the rebuilt surface.
CIVIL 3D 2014
The above procedure does not work with 2014.
(a) Index Colour, True Colour, or in Colour Books. If you have manually selected banding from these colour options, the Rebuild transforms the colours to those in the range of whatever “red, green, hydro” etc colour scheme is defined in the Settings box for the surface style.
(b) “Red, green, hydro” etc. colour schemes. If you start off with one of these schemes, a Rebuild transforms the Elevation/ Levels surface to a single colour.
After a Rebuild, it is possible to go through the whole exercise of manually re-entering the required colours. However, I work in coastal engineering dealing with large datasets generated by multi-beam echo-sounding for seabed terrains and land topography generated from LIDAR and it is now common practice to display these terrain surfaces in a “brown-yellow-green-blue-purple” colour scheme, such schemes having been generated as Colour Books using Autodesk ACDEditor.
Having to manually re-enter from the Colour Book after a rebuild is a laborious and time-consuming task. This will also be a major problem for those whose work involves using any of the proprietary Colour Books supplied with the package, such as the Pantone ones.
Consequently, having just upgraded to 2014 in the past week and found this bug with my drawings, it is evident that a lot of my work requires continued use of 2013.
Solved by neilyj666. Go to Solution.
Fantastic!
They finally fix surface elevation transparency, and now they #&*^#(** break this !
A quick test reveals that this happens on my test installation as well, so you're not alone.
The good news is that I'm sure Autodesk will get straight onto it and release a hotfix as soon as they hear about it 😛
Have you submitted this to Autodesk?
Cheers
- Mick
I just did a little testing myself and can confirm the issue. It's not just limited to if the data has changed, any time the surface is rebuild, all analysis of the surface (elevation, directions, watersheds, etc.) are lost.
neilyj (No connection with Autodesk other than using the products in the real world)
BTW Neilyj, your suggestion is the same as the response given by product support, who have 'referred it to the development team'. So I guess that means no fix real soon.
Hi Neilyj
The "surface analysis import/export" routine in the Toolspace Toolbox works only with Index Colours, so if you have generated a Levels/ Elevations display surface, say in 200 True Colours or from a Colour Book, the "surface analysis export" routine transforms the colours into Index Colours that bear no relation to the colour range of the initial surface.
Similarly, the "MapThematicRamps.ARM" is limited only to Index Colours.
Until the post of BrianHailey I was not aware that this problem applied to other aspects of surface analysis. Consequently, this suggests that it is a deep-seated problem in the code somewhere.
I have sent two reports to Autodesk and just received the polite reply of acknowledgement.
coastalgeology
This is the reply I got from Autodesk
"...Thanks for the link to the forum post. I do now understand what you mean.
Reset in the surface analysis do not actually occures when you open the drawing, but only when you rebuild the surface.
The analysis is recalculated every time the surface is rebuilded and range is reset (as it may change). It will re-use the defaut scheme. This works actually as designed.
Alternatively, you can use the tools from the country kit you mentioned in the forum post to reload color scheme.
If you like to see a different behavior, please use the product feedback page
and report in the details how you would like to have it work (What if surface change, what happen with range not yet defined, etc...). Using the product feedback link will ensure your wish go straight to the right people.
Thanks very much for your cooperation.
That being said, product support have this wish captured already, so I will add your voice to it in order to help define priority...."
At least you have had a reply.
The command of the English language in the reply is about on a par with the QA of their source code.
How can surface analysis being wiped out after a rebuild be classed as "...as designed"??
Surely if the analysis is recalculated correctly after each rebuild it should be revised with the parameters as defined pre-build. How else are Pantone Colour Books going to be used?
Restrictions limiting colour to Index Colours is definitely not compatible with engineering practice in the 21st century!
coastalgeology
and I had a subsequent reply:
"....You are correct, it did not behave the same way in previouse release. I believe this is because of a change request we have adressed, that being said, from a QA perspective, this works as designed by now.
I have reported and emphasis how important it is for you and some other folks out there and I can only suggest to use the link I provided to give a detailed description on how you like it to work (as explained previously)...."
Well this is gonna suck when we upgrade. We use the analysis to create earthwork exhibits (levels of cut/fill) that our clients can easily understand and they have commented how they like them. I know the functionality isn't lost, but having to reimport everytime we update is not going to be efficient.
-Tucker
I understand that you are experiencing issues with surface analysis after a rebuild. This was actually a change that was made moving to 2014 to make sure the analysis was always correct and not showing an analysis prior to any changes made to the surface.
This has been logged with Development and is currently under review, as many users find this unexpected behavior. This is a rather hot topic lately, so I will link this case to Development’s case so add some more “weight” to the issue
This was my answer to the support request. As I mentioned on my reply back sometimes I wonder who takes the decisions on changing the functionality. We use the analysis for exhibits as well and those are not done in the base file, but rather thru a dref in a plan sheet. Since the surface is dref that means when you open the file the surface is rebuilt. and the result is analysis gone. This is outrageus. What if I have let's say 50 non standards ranges? Do i need to recreate them every time to show the changes? Autodesk poll the people before changing functionality.
Since my original post, I have been experimenting with C3D 2014 and the use of RGB Colours (True Colours and Colour Books). The problem with the use of these colours for surface banding of Levels/ Elevations is not just confined to use of " Surface Rebuild".
If you have used RGB Colours for customised surface banding in C3D 2013 and re-open them in C3D 2013, the customised surface banding of RGB colours is retained. However, if you had re-opened them with C3D 2014, the surface banding is transformed into Index Colours.
Now comes the twist. In C3D 2014, if you change the colour scheme in the "Surface Analysis Dialogue Box" to RGB colours, and click on apply, the surface colours change to the RGB colours. However, when you save that file and re-open the file in C3D 2014, the RGB colours are transformed into Index Colours.
Conclusion. C3D 2014 is completely unuseable for using RGB colours for surface banding of Levels/ Elevations.
Cannot seem to make that happen. Am i wrong in what I show in the screencast? http://screencast.com/t/k3Opc3RWjTKo
