Can i install Civil 3d 2014 and Navisworks in one PC?
Computer Specs: i7, 8gb ram.
Solved by odoshi. Go to Solution.
Sure! You can install them as long as you have the hard drive space. The Infrastructure Design Suite contains a lot more than those 2 programs and is intended to go on a single computer.
Now, running them all at the same time is a different story. Your 8GB of RAM may get used up if you are running everything at once.
Mike
