Distinguished Contributor
CADEngr2014
Message 1 of 7 (381 Views)
CIVIL 3D 2014 AND CIVIL 3D 2013
381 Views, 6 Replies
01-15-2014 06:17 AM
We are running C3D 2014.
We have a need to run C3D 2013, due to other applications not yet compatible with C3D 2014.  Does anyone know what the issues may be running the two versions on the same computer?
Jay_B
Message 2 of 7 (373 Views)
Re: CIVIL 3D 2014 AND CIVIL 3D 2013
01-15-2014 06:35 AM in reply to: CADEngr2014
Shouldn't be any issues.
I have 2012, 2013 & 2014 all installed and no issues whatsoever due to them all being installed on system.
If you were to try to do a back & forth workflow from 2013 to 2014 then I'm guessing you could have a few issues
and I'd recommend against that workflow.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
rkmcswain
Message 3 of 7 (362 Views)
01-15-2014 07:41 AM in reply to: Jay_B
Ditto. We have several people wioth 2013 and 2014 installed, no problems.
FWIW....
I have personally (and purposly) mixed these two versions in the workflow and have only run into one issue.
At one point, one alignment out of several failed to show up in 2013 after it was edited in 2014. We opened the drawing in 2014 (the alignment was there) and saved again, and then 2013 could see it again.
Points, surfaces, profiles, profile views, and data shortcuts have been working in a mixed environment with no problems.
Jay_B
Message 4 of 7 (350 Views)
01-15-2014 07:53 AM in reply to: rkmcswain
rkmcswain wrote:
FWIW....I have personally (and purposly) mixed these two versions in the workflow and have only run into one issue.
That's good to know, that's exactly why I mention "could". There are several caveats that can change could to would such as updated Pressure Networks and any other new functionality in 2014 AFAIK.
Jay
C3D 2014 SP2
rkmcswain
Message 5 of 7 (346 Views)
01-15-2014 08:04 AM in reply to: Jay_B
Yes, I should have mentioned that. There are documented issues with Pressure Networks, etc. in the 2014 help file (topic title = "Round-Tripping Data Between the Current Version and the Previous Version of AutoCAD Civil 3D"), and a good blog post on it here.
troma
Message 6 of 7 (336 Views)
01-15-2014 08:32 AM in reply to: rkmcswain
I saw some posts also about Gradings. I think it was that gradings made in 2014 don't show up in 2013, or something like that.
Credit where credit is due! Give kudos or accept as solution whenever you can.
TRogers
Message 7 of 7 (317 Views)
01-15-2014 10:41 AM in reply to: rkmcswain
I reported a bug to Autodesk a few weeks ago with the transformation setting in Drawing Settings.  If you set a transformation in 2014, it will "zero" out the values in 2013 and will not do the transform.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
