the autocad loading screen comes up and stops at "Opening drawing\C:\users\................ncs.dwt....0%"
it does this often, and i try to restart my computer and sometims that works. it also did this to me when i was using 2012. is it because i have the minimum requirements for RAM? (4GB)
thank you
Solved by Jeff_M. Go to Solution.
I've seen this occur when the last session of C3D does not exit cleanly. leaving WSCommCntr*.exe running. Next time this happens, start Task Manager, switch to the Processes tab, scroll down and find WSCommCntr*.exe (the * will be a number, depending on version), select each one EXCEPT the first, hit the End Process button. If there is only one listed, then this isn't the same problem you are seeing.
Clarification. If it is 2013 not starting, and there is a WSCommCntr3.exe listed but C3D2012 is not running, then this is the one that must be killed. Conversely, if starting 2012 and there is a WSCommCntr4,exe running when C3D2013 is not, kill that one.
thank you , that was very helpful...now i have another question...how do i get the trimble link on to my C3D ribbon? in 2012 i have the link and i forget how i got it there. does trimble even have one for 2013 yet?
