Hi frinds,I'm using autocad 2013,all templet is there except civil 3D, can some one help me how to recover it.thanks.
Solved by Jay_B. Go to Solution.
dcutter,thanks for your reply,I don't have any Idea about that,the Instaltion done by It department,why the civil 3d is not a part of autocad 2013?thanks
No, Civil 3D is not part of a plain AutoCad installation.
Check to see if it's installed on your system here:
Windows Start Menu > All Programs > Autodesk > AutoCAD Civil 3D 2013.
If you don't see AutoCAD Civil 3D 2013 listed at above location, then it's likely you do not have 2013 Civil 3D installed.
