Civil 3D Forum
Civil 3D 2013 Surface display graphics settings
9 REPLIES 9
Message 1 of 10
omriyc
394 Views, 9 Replies
hey
when i am working with multiply surfaces ( earthwork) how can i seperate the diplay setting for each surface?
the deafult is that they are all connected
thanks
omri
9 REPLIES 9
Message 2 of 10
Jay_B
in reply to: omriyc
Where would you like to change the Surface Style?
Are these surfaces which are displayed Section Views or?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 10
omriyc
in reply to: Jay_B
in the surface style. when turning elevations on in one surface all the other surfaces are on also. i want to affect each surface separately
Message 4 of 10
Jeff_M
in reply to: omriyc
Assign different styles to each surface.
Message 5 of 10
omriyc
in reply to: omriyc
i can Assign different styles to each surface but when turning off elevations in the surface style it turns off at all the other surfaces
i need to control each surface individualy. for now they are all connected
Message 6 of 10
Jeff_M
in reply to: omriyc
How are you turning off the elevations? Are you using the layer off/freeze or the Visible property in the Style's display properties? Can you share your drawing here?
Message 7 of 10
omriyc
in reply to: Jeff_M
i send one file for example - one surface is the current base, one is the design of the new topography and the last one is the tin volume surface - is it for earthworks in the attachment you can see the area colored magneta which is the cut volume and the blue comes from another surface. i want to display only the magneta from the volume surface only
Message 8 of 10
omriyc
in reply to: omriyc
i sent the file. i'm controlling the surface display through the edit style layers visible on/off
Message 9 of 10
Jeff_M
in reply to: omriyc
Surface1 & Surface4 are both using the same style. Changing Surface4 to a different style allows just the Magenta to display.
Message 10 of 10
omriyc
in reply to: omriyc
thank you!
Rail Community
