hey
when i am working with multiply surfaces ( earthwork) how can i seperate the diplay setting for each surface?
the deafult is that they are all connected
thanks
omri
Solved by Jeff_M. Go to Solution.
in the surface style. when turning elevations on in one surface all the other surfaces are on also. i want to affect each surface separately
i can Assign different styles to each surface but when turning off elevations in the surface style it turns off at all the other surfaces
i need to control each surface individualy. for now they are all connected
i send one file for example - one surface is the current base, one is the design of the new topography and the last one is the tin volume surface - is it for earthworks in the attachment you can see the area colored magneta which is the cut volume and the blue comes from another surface. i want to display only the magneta from the volume surface only
i sent the file. i'm controlling the surface display through the edit style layers visible on/off
