Member
0 Kudos
Post 1 of 16
CIVIL 3D 2013 RUNNING ON WINDOWS 8
2466 Views, 15 Replies
01-23-2013 11:16 AM
I recently upgraded my computer to run Windows 8 Pro.  Everything is working great except for the grading functions in Civil 3D.  All other areas function fine but when I am in a grading plan and try to do anything the program crashes and shuts down, any suggestions?
I appreciate all the discussion, I too will be going back to Windows 7 tomorrow.
Thanks again...
654 Kudos
Post 2 of 16
Re: CIVIL 3D 2013 RUNNING ON WINDOWS 8
01-23-2013 11:48 AM in reply to: lwalker
Windows 8 is not a supported OS for Civil 3D which means autodesk did not test it on windows 8 so what ever problems you run into my or may not get fixed in 2013
you can look through here for issues and workarounds other people have posted: http://forums.autodesk.com/t5/forums/searchpage/tab/message/?page=2&q=windows+8&search_type=thread
Member
0 Kudos
Post 3 of 16
01-23-2013 03:22 PM in reply to: lwalker
So you are saying this problem with windows 8 and civil 3d crashing will not be fixed this year? Are they attempting to fix this?
654 Kudos
Post 4 of 16
01-23-2013 03:24 PM in reply to: john_gildersleeve
maybe or maybe not
windows 8 came out after civil 3d 2013 was released
may have to wait until 2014 to release for a fix
Member
0 Kudos
Post 5 of 16
01-23-2013 03:29 PM in reply to: john_gildersleeve
So how do you go about trying to get these problems fixed? Is autodesk attempting to try to help out? If so how do I get in touch with support?
912 Kudos
Post 6 of 16
01-23-2013 03:39 PM in reply to: john_gildersleeve
I don't, since I know that C3D2013, and earlier, is not officially supported by Autodesk. Nor do I expect them to. When the next version is released, assuming it will be Win8 compliant, then I may get a new PC with Win8. In the meantime, I will continue to work without too many progam errors with my trusty Win7 and C3D 2012/2013.
If you want to submit a support request, there is a mechanism for that in the Subscription site. Not on Subscription? Then there's the web form: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
308 Kudos
Post 7 of 16
01-23-2013 05:03 PM in reply to: john_gildersleeve
You won't necessarily get this issue fixed, at least not by Autodesk. There might or might not be a service pack for 2013 to address this issue.
I have had a couple clients who installed using Windows 7 Compatibility Mode and are up and running with no errors.
Also, you if you want to spend some time with it, you can test in diagnostic startup. If that works, try selective startup and one-by-one re-apply the services you turned off. Eventually you'll find one that's conflicting with grading. This could take hours.
Personally, I am doing what JeffM is doing. I'll install Win8 when Autodesk says they support it. At this point they have not said that.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
0 Kudos
Post 8 of 16
01-23-2013 05:27 PM in reply to: john_gildersleeve
Not sure how you install using windows 7 compatibility mode, do you mean once it is installed to click on the program and set it to run in compatibility mode? Thanks Larry H. Walker, PE President walker associates engineers 32 Clarksville Street | Suite 202 Paris, Texas 75460 M| 903-272-5231 lwalker@wacivil.com
654 Kudos
Post 9 of 16
01-23-2013 05:27 PM in reply to: lwalker
yes
Member
0 Kudos
Post 10 of 16
01-23-2013 06:22 PM in reply to: lwalker
Good idea, but it did not work for my CAD. It crashed just as fast with the changes you described. I am going to end up switching hardrives to run Windows 7 inorder to run CAD. This will be alot of work and I am not real happy about it. I am going to warn everyone I know that uses CAD, that Windows 8 and CAD are not a good mix.
