Valued Contributor
BtimmermanMMS
Message 1 of 5 (615 Views)
Civil 3D 2013 - Point marker with attributed block
615 Views, 4 Replies
01-24-2013 09:52 AM
How do you get a point marker that uses a block with attributes to show the attributed text?
We are using tree symbols that have the size of the tree as an attribute, but when the points that use that block come in...the block shows up w/out any attributed text. Tried to edit the "block" or point marker with attedit command, but C3D tells me it is not a block. Understand that it is a "marker" for the point. But, what is stopping the text size of tree from showing up?
Any help greatly appreciated.
*Pro
dgordon
Message 2 of 5 (614 Views)
Re: Civil 3D 2013 - Point marker with attributed block
01-24-2013 09:57 AM in reply to: BtimmermanMMS
attributes don't work thru point markers.   use the point label style to show this text information.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
BtimmermanMMS
Message 3 of 5 (607 Views)
01-24-2013 10:31 AM in reply to: dgordon
I see the options under the component name (Text, Line, Block). But, I do NOT see any options for attributes. Where does one find the options to add attributes to the label style for the point.
One solution a co-worker had was to explode the points. They've been causing some issues besides this one...
troma
Message 4 of 5 (603 Views)
01-24-2013 10:50 AM in reply to: BtimmermanMMS
Don't use attributes.  Use the label to show the size of the tree.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
d1of2
Message 5 of 5 (584 Views)
01-24-2013 12:16 PM in reply to: BtimmermanMMS
Basically, you point description becomes an attribute. Actually the attribute has grown up to the point description?!
Windows 7 64
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
