Civil 3D Forum
Civil 3D 2013 - Point marker with attributed block
6 REPLIES 6
BtimmermanMMS
1181 Views, 6 Replies
How do you get a point marker that uses a block with attributes to show the attributed text?
We are using tree symbols that have the size of the tree as an attribute, but when the points that use that block come in...the block shows up w/out any attributed text. Tried to edit the "block" or point marker with attedit command, but C3D tells me it is not a block. Understand that it is a "marker" for the point. But, what is stopping the text size of tree from showing up?
Any help greatly appreciated.
6 REPLIES 6
in reply to: BtimmermanMMS
attributes don't work thru point markers.   use the point label style to show this text information.
BtimmermanMMS
I see the options under the component name (Text, Line, Block). But, I do NOT see any options for attributes. Where does one find the options to add attributes to the label style for the point.
One solution a co-worker had was to explode the points. They've been causing some issues besides this one...
troma
Don't use attributes.  Use the label to show the size of the tree.
Mark Green
Working on Civil 3D in Canada
Basically, you point description becomes an attribute. Actually the attribute has grown up to the point description?!
jdelamora1
Is ther a way to convert points with attributes to blocks with attributes.  I have points with attributes, and I need to covert them to blocks.  When I do that I loose all my attributes?
sboon
in reply to: jdelamora1
You do not have points with attributes.  Civil3d points are not blocks and they do not store data that way.  If you export the drawing then you can get blocks (if that was part of the point style,) and text.
There might be a third party tool that could do this.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Rail Community
