In previous versions of Civil 3D there was a grip on the point marker that allowed me to rotate the block used as a point marker, where did this grip go in 2013? How can I rotate an individual point marker without having to create a separate point style?
Solved by sboon. Go to Solution.
The marker is still there, but it's now combined with the point movement grip. Select the point and hover over the square grip - you should get a flyout menu with options for move or rotate.
When I hover the selected point the flyout menu does not appear. What setting am I missing?
Dan Seymour
Feist Engineering, Inc.
