Civil 3D Forum
Civil 3d 2013 Point Classification
18 REPLIES 18
Message 1 of 19
TJPlace8461
1797 Views, 18 Replies
I just upgraded to 2013 and I attempted to create a point cloud from a LAS file.  My Point Cloud Classification has only Ground checked.  However after the creation, my point cloud seems to have all the points.  It does not seem to be filtering out the trees.
18 REPLIES 18
Message 2 of 19
Congratulations...  I think you found a bug.  I am able to reproduce this error.  I imported an isd file from 2011 that applied the classification style correctly.  In 2013, the classifications don't work.
Civil 3D 2011 style showing ground points only:
In 2013, the classifications are ignored.  I tried this with the existing isd file and by importing the las data into a new isd file.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 3 of 19
osbornm
in reply to: david.zavislan
Yes, there is a bug here.  Funny thing is, if you open a 2012 (or before) drawing containing a point cloud in 2013, then the classification styling works correctly.  Very odd.
Message 4 of 19
TJPlace8461
in reply to: osbornm
Just checking back to see if this issue has been resolved?  If so, what do I need to do?
Message 5 of 19
osbornm
in reply to: TJPlace8461
Currently the workaround is to create the C3D point cloud object in 2012 and bring it forward to 2013.  Then the classification data is recognized and displayed properly.  The fix for 2013 would have to come in a service pack.
Message 6 of 19
TJPlace8461
I have been creating the point clouds in 2012 and it is working fine, but it would be much more convenient to do it all in 2013.  Any word on a possible patch or service pack to resolve this issue?
Message 7 of 19
ewatson
I also have this issue.  Would love to see a fix!  It only took my a couple hors of pont cloud generation and regeneration to figure this one out.
Message 8 of 19
ceethreedee.com
in reply to: ewatson
Yep count me in! Point Classification fail.
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Message 9 of 19
tcorey
Has anyone tried this in 2013 with the new service pack 1?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 10 of 19
tjplace1
I have upgraded to SP1 on 2013 and the glitch still exists.  I am very disappointed in Autodesk for the amount of time it is taking to resolve this.
Message 11 of 19
ceethreedee.com
in reply to: tjplace1
Plus 1 on Serivce Pack 1 still with issues.
Infraworks 2021.1,
ceethreedee.com
Message 12 of 19
rjairath
in reply to: ceethreedee.com
classification failure with sp1
Thank you for reading,
Win7 64bit Pro
Xeon E5-1620 v2, 3.70GHz, 32GB Ram
Please mark solution found if this post solved your issue or give kudos when appropriate.
Message 13 of 19
gccdaemon
Same issue here as well, confirmed with SP1.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 14 of 19
TJPlace8461
Does anyone know if this issue is resolved in Civil 3d 2014?
Message 15 of 19
osbornm
Yes, it should be working in 2014.
Message 16 of 19
ceethreedee.com
Yeah... "Should be" and "Is" are two entirely different scenarios.
Do you have any proof it is working?
Regards
Infraworks 2021.1,
ceethreedee.com
Message 17 of 19
Cadguru42
With 2014 being backwards compatible to 2013, would that allow 2013 to display them correctly if it was done first in 2014?
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 18 of 19
tcorey
Yes, I can confirm this works in 2014.
Tim Corey
Redding, CA
Message 19 of 19
gccdaemon
in reply to: tcorey
Confirmed with 2014 as well. Looks like Autodesk was doing a lot of programming work with point clouds and 3D imagery so the decided to leave it out of 2013 until they made it stable enough to use.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
