Active Contributor
aluko0719
Message 1 of 6 (1,084 Views)
civil 3d 2013 how to change static to dynamic in profile views
1084 Views, 5 Replies
05-03-2012 09:33 AM
in civil 3d 2013 i have a existing surface, alignment, and profile that is data linked into another drawing when i create a profile view from the profile data link when i get to the profile display options under update mode it shows as beening static, i don't want it to be static i want it to be dynamic. is there a way or setting that will let me change that to static? we show the existing grade as hidden but with the static option set the grade shows up with long and short
Unfortunately you can't. The current workaround is to datareference in the surface and then create a surface profile in that drawing for your alignment. This way if the surface changes, the profile changes and you can use linetypes.
BrianHailey
Message 2 of 6 (1,073 Views)
Re: civil 3d 2013 how to change static to dynamic in profile views
05-03-2012 10:28 AM in reply to: aluko0719
Brian Hailey
CAD-1.com
My Blog
Active Contributor
aluko0719
Message 3 of 6 (1,029 Views)
05-06-2012 04:54 AM in reply to: BrianHailey
thanks for the answer. i hope they fix this in a patch. in 2012 the line comes in as dynamic.
Jeff_M
Message 4 of 6 (1,024 Views)
05-06-2012 07:08 AM in reply to: aluko0719
aluko0719 wrote:
... in 2012 the line comes in as dynamic.
It has never been dynamic for me, in C3D2007-C3D2012. I have always used the same method Brian described.
Active Contributor
aluko0719
Message 5 of 6 (1,014 Views)
05-06-2012 11:23 AM in reply to: Jeff_M
for us, in 2012 it always data linked as dynamtic and you could change it static
Distinguished Contributor
csevers
Message 6 of 6 (455 Views)
11-05-2013 01:04 PM in reply to: aluko0719
I had the same problem, thanks.
Chris Severs, EI
Windows 7 x 64 bit
NVidia Quadro 2000 Dual Monitor
6.00 GB RAM
Intel Xeon W3550 @ 3.07 GHz
Civil 3D 2013 SP 2, Civil 3D 2012 SP2, Civil 3D 2011 V3, Civil 3D 2010 V3
