Civil 3D Forum
Civil 3D 2013 - Hangs on startup
3 REPLIES 3
925 Views, 3 Replies
Looks like something to do with 360 is cause C3D2013 to hang on startup.  I have to kill the AcSettingSync.exe service to in Resource Monitor to make 2013 un-freeze.  Any ideas?
3 REPLIES 3
LeafRiders
Uninstall and go back to Civil 3D 2012 until SP1 is released for CIvil 3D 2013.
It might have something to do with the Cloud360 application, the patch seems to have helped.
phil_borycens
Hi Sean,
It sounds like you may have applied the Hotfix for Autodesk 360 Sync errors? Whatever the case, I'm glad to hear that it has helped.
A lot of times the Communication Center process causes Civil 3D to hang on launch too. You can kill it in Task Manager whenever this happens, just look for the WScommcntrX.exe process. For a more permanent solution to this, you can disable it in the registry or by using the CAD Manager Control Utility. These options are discussed here:
http://beingcivil.typepad.com/my_weblog/2012/07/how-to-disable-communication-center.html
I hope this helps, and I hope you have a great weekend!
Phil
Phil Borycens
Rail Community
