Active Contributor
0 Kudos
Post 1 of 8
Civil 3D 2013 Crashing on Export to CAD when pipes in profile view
909 Views, 7 Replies
01-10-2013 03:45 PM
So I have been getting a fatal error "INTERNAL ERROR: !dbobji.cpp@8743: eNotOpenForWrite" when I try to export to 2010 CAD.
I have worked out that it happens when pipes are displayed in the profile view.
ANyone have this problem or know of a fix?
We ended up redoing the drawings and all is working fine now.
307 Kudos
Post 2 of 8
Re: Civil 3D 2013 Crashing on Export to CAD when pipes in profile view
01-10-2013 04:42 PM in reply to: Jon0001
Did try a Recover?
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
0 Kudos
Post 3 of 8
01-11-2013 07:50 AM in reply to: tcorey
Yes we have tried a recover and audit and removed all xrefs
264 Kudos
Post 4 of 8
01-11-2013 10:35 AM in reply to: Jon0001
Check that none of the layers associated with pipes in profile view are locked/frozen.
Test: try exporting to ACAD 2013 first.  Then open that up and export again to 2010.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
0 Kudos
Post 5 of 8
01-14-2013 07:19 AM in reply to: troma
Member
0 Kudos
Post 6 of 8
06-20-2013 05:46 AM in reply to: Jon0001
Keep getting the internal error.
Jon0001, redoing the drawings? What did you do exactly?
Active Contributor
0 Kudos
Post 7 of 8
06-20-2013 07:31 AM in reply to: Jon0001
We ended up purging the Civil 3d of all excess settings and styles and it seemed to work.
Member
0 Kudos
Post 8 of 8
08-06-2013 10:52 PM in reply to: Jon0001
Decided it would be the same or easier way: save c3d .dwg with proxy images, then open .dwg in plain autocad [, explode proxies and finally remove proxies if it's nessesary].
