Civil 3D Forum
Civil 3D 2013 Crash after regen
13 REPLIES 13
Message 1 of 14
eric-acevedo
1781 Views, 13 Replies
I have a situation where some profileviews does not show the gridlines and border, then, after a regen they appear, but  a couple of seconds later Civil 3D crash.
Any help is appreciated.
Eric
Tags (1)
13 REPLIES 13
Message 2 of 14
troma
in reply to: eric-acevedo
More info:
Computer specifications.
C3D version.
Drawing history.
Try running a recover on the drawing.
Mark Green
Working on Civil 3D in Canada
Message 3 of 14
eric-acevedo
in reply to: troma
Dell Inspiron T3500
24 GB Ram / 250 GB
Quadro FX 580
C3D 2013 SP1.
Windows 7, 64
I did Purge, Recover, Audit with no success.
I also checked broken datashortcuts.
Error message:
FATAL ERROR:  Unhandled Access Violation Reading 0xffffffff Exception at e1968c0eh
Attached is the file.
Eric
Message 4 of 14
Jay_B
I'm able to open it just fine with 2013 no Service Packs installed.
It's not finding 4 data referenced surfaces, take a look at if one of those could be causing issues.
Attached is a caption of the profiles - The data bands & grids all look ok.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 5 of 14
Jay_B
in reply to: Jay_B
Forgot to mention did regen & regenall too.
C3D 2018.1
C3D 2016 SP4
Message 6 of 14
klugb
in reply to: Jay_B
I also checked it with 2013 with SP1 and no problems here. Same issue on missing DS's.
I also tried regen, regenall, zoom extents, and even went into each profile view properties to see if that would kick me out. All was good.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 7 of 14
eric-acevedo
in reply to: Jay_B
Thanks Jay,
I updated the datashortcuts but the problem persists.
I did regen and the grids appears, but just when I move the mouse, the program crash.
Thanks again,
Eric
Message 8 of 14
Jay_B
Eric,
Try running an audit on all individual drawings in play here.
The drawing you posted and ALL xrefs and Civil 3D source drawings drefs were created from.
C3D 2018.1
C3D 2016 SP4
Message 9 of 14
eric-acevedo
in reply to: Jay_B
OK, I'll do that.
Message 10 of 14
eric-acevedo
in reply to: klugb
Thanks Bruce
Message 11 of 14
GlennPope
Have this same exact issue.
Dell XPS
16 GB Ram / 1 TB
AMD Radeon HD 7570
C3D 2013 SP2.
Windows 7, 64
Have done the purge, audit, & recovery. Also started a new drawing from scratch. Same issue. Exactly configured machine that we just got with a fresh install and patched to SP2 has no issues. Had been working fine on my system for a while. This is a pretty recent development. So far the only thing I can think of that has changed was installing the 2014 Design Suite.
Actually have the same issue in C3D 2014. Up to date and using out of the box settings.
Glenn Pope
Civil Designer/CAD Manager
Green Civil Design
Message 12 of 14
Jay_B
in reply to: GlennPope
Glenn,
Might not hurt to post to Re: Are you experiencing recurring crashes? If so, we'd like to hear from you thread re: 2013 installs w/ crashing issues.
C3D 2018.1
C3D 2016 SP4
Message 13 of 14
GlennPope
in reply to: Jay_B
Apparrently my issue was caused by installing the 2014 Infrastructure Design Suite. Part of the installation installs the Autodesk Geotechnical Module. Which had some nasty bugs in it. I tested created a profile view in 2014 and had the same results. After sending in the crash report that was generated, I got an email from Autodesk stating this was what was causing the issue. This apparrently causes issues in other versions of C3D.
The module can be uninstalled on its own. By using the Windows Contol Panel. There is a newer version in the subcription center if you need the functions from this module.
Glenn Pope
Green Civil Design
Message 14 of 14
We experienced the same issue with drawing profile views and this solved our problem. I never would have been able to troubleshoot this easily on our own. Thank you.
Rail Community
