Civil 3D Forum
Civil 3D 2012 not responding when switching to model tab
6 REPLIES 6
1294 Views, 6 Replies
I have a drawing that is "Not Responding" when switching from a layout tab to model space by clicking the "Model" tab.  I ran a recovery on the drawing and there are no errors.  I can't get into model space except by clicking inside my viewport.  How can I fix this?
6 REPLIES 6
wfberry
Try this:
In the command line
tilemode
set it to 1
Set it to 0 if you need to go back to layout.
in reply to: wfberry
I have the same problem - model space not responding when I move from layout tab to model tab.  I've tried resetting the tilemode but it locks up.
I'm using Civil 3D 2012 as well
sboon
I would suggest that you make a backup copy of the drawing and all associated files, and then try either the Recovery command or a full RecoverAll operation.
Steve
Expert Elite Alumnus
in reply to: sboon
Thank you and let me give you the lowdown on the process.  I resaved the drawings as a new file. "Recoverall"
It is asking me to convert VBA content to .net.   I have been approving that but maybe that is not a good idea?
I have reopened the new file . no luck getting into model space . . . . perhaps I should have converted the VBA  to .net?
tilemode worked for me.
C3D would not switch to model, and then not respond.
Rail Community
