When I click on Edits under the Surface Definition in Prospector, the program will hang, and I will have to shut it down through Windows Task Manager. This is when there are Edits to the surface (Edge Swaps mostly).
Solved by Jeff_M. Go to Solution.
Try hitting the CTRL key when this occurs. Many of us have found C3D2012 to appear to lockup when selecting different items in the Prospector but using the CTRL key will bring it back to life.
Thanks Jeff!
Tested this and it worked for me. Had to press a couple times on one instance.
Thanks for this great tip! This will help to keep me moving in the forward direction >>> Wish I would have known awhile back...
Best Regards,
Fred
