Civil 3D Forum
Civil 3D 2012 crash...had to reinstall...now it won't run
1 REPLY 1
johntrla
197 Views, 1 Reply
Good morning,
C3D crash and I reinstalled.  Entered an activation code given to me by Autodesk because serial number was not recoginized.  After I entered activation code I received an error message that stated:
"Autodesk component has stopped working...A problem caused the program to stop working correctly.  Windows will close the program and notify you if a solution is available"
Then C3D gets hung up and I have to close it out.
PLEASE HELP!!  THANKS!
John T.
John T.
1 REPLY 1
andrewpuller3811
in reply to: johntrla
Try getting civil 3d to run the secondary installer again.
Do a search of the forum or check the Autodesk site for "Resolving user specific issues by resetting AutoCAD Civil 3D 2012" - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18353335&linkID=9240697
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
