Good morning,
C3D crash and I reinstalled. Entered an activation code given to me by Autodesk because serial number was not recoginized. After I entered activation code I received an error message that stated:
"Autodesk component has stopped working...A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available"
Then C3D gets hung up and I have to close it out.
PLEASE HELP!! THANKS!
Try getting civil 3d to run the secondary installer again.
Do a search of the forum or check the Autodesk site for "Resolving user specific issues by resetting AutoCAD Civil 3D 2012" - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18353335&linkID=9240697
