Distinguished Contributor
bigblittlerent
Message 31 of 49 (2,582 Views)
Re: Civil 3D 2011 runs slow and likes to "not respond"
11-08-2010 10:25 AM in reply to: Bugpop
Just a thought...
Civil 3D writes an instance of the image to your local TEMP directory.  I have noticed serious performance issues with a cluttered temp directory.
Bugpop
Message 32 of 49 (2,565 Views)
11-08-2010 11:37 AM in reply to: bigblittlerent
It does this when using the Autodesk FDO for Provider for Raster, however my regens are not unreasonable when inserting raster images in this manner.
When I attach images in the reference manager or using Raster Design I am not aware of local instances saved to temporary directories.
To be sure I have created new temporary directories for Civil 3D to use but the problem persists when images are attached in the reference manager.
justin_hogan
Message 33 of 49 (2,551 Views)
11-08-2010 12:11 PM in reply to: oceanside
I cant even get into AutoCAD.  it freezes up before the application lauches.
Bugpop
Message 34 of 49 (2,542 Views)
11-08-2010 12:31 PM in reply to: justin_hogan
It's probably another issue
Open up Task Manager and see if WSCOMMCNTR2 is still running.
End the task
justin_hogan
Message 35 of 49 (2,487 Views)
11-10-2010 12:41 PM in reply to: bigblittlerent
AutoCAD wont even load long enough to load the WSCOMMCNTR2  or maybe that is the problem it doesnt load the WSCOMMCNTR2???
Just did a fresh install per Autodesk instructions and still not responding after it starts to load.  never gets to the splash screen.
neilyj
Message 36 of 49 (2,462 Views)
11-11-2010 05:51 AM in reply to: bigblittlerent
...and this is another thing that occurs all too frequently... and inevitably causes a lot of rework
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
New Member
nathan1899
Message 37 of 49 (1,961 Views)
02-25-2011 05:20 AM in reply to: tfboles
For me if I not disable but totally exit out of Norton my issues go away.  I believe Norton is stopping some of the processes in C3D.  C3D would start to "not respond" for many things that seemed unconnected but when I shut off Norton it fixed the issues.
Civil 3D 2011 SP1
Win 7 Pro x64
4Gb Ram
ATI Firepro 4800
Dell T3500
Valued Mentor
gccdaemon
Message 38 of 49 (1,949 Views)
02-25-2011 06:13 AM in reply to: nathan1899
We're using Nortons Hosted Endpoint Protection and we don't have the long hangs like you guys are discussing.
I am experiencing a problem with my graphics card locking up my OS and have to hard reboot, but that seems to happen in other graphics heavy applications IE Google earth.
As for the not responding messages, those only pop-up because you're clicking on and off the program when it's still processing and doesn't not actually mean that autocad has locked up.
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
Active Member
tfboles
Message 39 of 49 (1,940 Views)
02-25-2011 06:42 AM in reply to: bigblittlerent
It has become my routine to disable norton for 5 hours at a time.
once the problem starts you must exit acad to stop it. (and possible reboot??)
Disabling norton after the first occurance will not stop it
justin_hogan
Message 40 of 49 (1,925 Views)
02-25-2011 07:24 AM in reply to: tfboles
Had a similar problem with AutoCAD and Inventor 2011.   Go to the control panel, add/delete programs, and click on the .NET framework.  When it asked to remove or repair simply click on repair.  This will fix it.
