When you have Xrefs attached the LayerManager will normally select the Xref
Filter (I'm not sure why, this ticks me off as I usually do not want that
filter....), thereby only showing you the Xref layers. When you create a new
layer, while that filter is active, it disappears from the list because it
is nor an Xref layer.
The new Layer1 will also disappear if you have any other filter set active
that would not normally show that layer name.
"mdriver1" wrote in message news:6336710@discussion.autodesk.com...
> I posted about this very subject a few moons ago but found something
> interesting this morning regarding the above relationships.
> To start, the previous post concerned the inability to create a new layer
> by simply hiting the "create new layer button" on the layer manager. I
> then proceeded to explain that I could create a layer all day long via
> the -layer command.
> On to today and my findings by luck maybe?
> I noticed that while trying to create a new layer by hitting the "create
> new layer button" in layer manger the Layer1 wasn't showing up to be
> renamed as it should? Strange.
> As most would I kept trying by hitting the button. Well I found that by
> detaching the one and only XREF all 7 new layers immediately showed in
> layer manager (Layer1, layer2, etc.).
> Information on the XREF. Yes it is from another party, a architect to be
> exact, but I have had this problem with XREFS in general, I think, but
> cannot prove it to date.
> If this is a problem why does Civil 3D have such a problem with XREFS? It
> didn't used to be that way. I have always found XREFS to be very stable in
> LDD (I know I had to refer to it and do not like to compare anymore but
> Not really bitching here but want to know if I'm missing something so this
> can go away? Do I need to change my workflow in how I handle XREFS?
> Thanks,
> Mark Driver
