**SOLVED** **KIND OF**
I ran into this problem while testing some builds (C3D 2010 on Win7 x64). We copied the Content folder from the DVD into the network installation package and did reinstalls through Add/Remove Programs. This worked fine; however, in preparing for the full office-wide deployments we decided to take Autodesk's wonderful advice in copying the contents of the installation DVDs to a local drive and creating a deployment from there. My own lack of testing ended up in an office-wide deployment wherein the tool palettes were still empty, just as they were in the first deployment.
This brought me to trying to find a way to resolve the issue without having to spend a half hour repairing every CAD installation in the office. I'll cut to the chase:
Autodesk's only suggestion is to copy the Content folder from the installation DVD to the network installation package and then do a reinstall of each computer's CAD installation.
My solution is as follows:
The repair only needs to be done on one computer, then there are a handful of files that can be copy/pasted to each machine to resolve the issue.
From the repaired computer, copy the entire contents of C:\Users\%username%\Appdata\Autodesk\C3D 2010\enu\Support\ToolPalette.
From the repaired computer, copy the contents of C:\Users\%username%\Appdata\Autodesk\C3D 2010\enu\Support\RegisteredTools.
The RegisteredTools folder should already contain an catalog file called AcTpTools.atc. Two others (ADTMtlStockTools.atc and C3DStockTools.atc) are ones that need be copied.
Paste these items into the corresponding folders of each installation that needs be repaired. Restart CAD and the tool palettes should be available.
Disclaimer: This solution worked on a Civil 3D 2010 installation on Windows 7 64-bit OS. Other variables in installation packages, or customized tool palettes may conflict with this solution. However, for me, this worked and probably saved 20+ billable hours.
PS: Great job, Autodesk, on the wonderful variety of solutions you've provided to this well-known issue.
Edited by: EskewAK on Apr 19, 2010 9:50 PM
Edited by: EskewAK on Apr 19, 2010 9:51 PM
