Civil 3D Forum
Civil 3D 2010 Pipe crossing full ellipse style
10 REPLIES 10
Message 1 of 11
sharin1
2044 Views, 10 Replies
How would I make a part that appears as an ellipse the size of the crossing pipe?
10 REPLIES 10
Message 2 of 11
in reply to: sharin1
The program already does this if I am reading you correctly. It allows for
the vertical scale differential as well as the angle of the section for a
crossing pipe. You need to select the proper style in the pipes Tab.
Bill
wrote in message news:6260604@discussion.autodesk.com...
pipe?
Message 3 of 11
sharin1
I cannot make the style become an ellipse inside a manhole, it shows as an outer pipe part outside of the manhole instead of insude of it. See attached PDF. Also how do you show a line that crosses a line that is profiled? It has to be in the same network, correct?
Message 4 of 11
charlesl300
you need to turn off "enable part masking" for that particular structure style.
Also, the FACETDEV setting should be set lower, to draw more vertices in the crossing pipe, thereby more closely resembling an ellipse.
Hope this helps,
Chuck Lamping, PE
Lamping Consulting, LLC
www.lampinglllc.com
Chuck Lamping, P.E.
Westwood Professional Services
EMAIL chuck.lamping_at_westwoodps.com
WEB www.westwoodps.com
Message 5 of 11
sharin1
Where do I un mask it?
Message 6 of 11
charlesl300
Oh, and to your other question, any network can be shown in any profile of an alignment that crosses it. Just pick it and add it to the profile, then change the style of the pipe in its properties to crossing pipe style.
-Chuck
Chuck Lamping, P.E.
Message 7 of 11
charlesl300
In the part style, be it a manhole or junction box. Right-click on the structure in the profile and go to "edit structure style".
In the profile tab, under the preview box, uncheck "Enable part masking".
-Chuck
Chuck Lamping, P.E.
Message 8 of 11
MikeEvansUK
that is use an overide style for the part on the profile / section view properties otherwise it will change in the plan and 3d views as well. Nice didnt know the facets worked for them, never tried it. So that may help with pipe crossings.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 9 of 11
charlesl300
Yes, Mike, good point. Override the style of that particular crossing pipe in the profile view properties, don't change the style of all the pipes.
Chuck Lamping, P.E.
Message 10 of 11
sharin1
Thank you so much!
Message 11 of 11
sharin1
Thanks!
Rail Community
