I found the ribbon to be quite disorientating when I first experienced it. The biggest annoyance was having my tool bar context change whenever I picked a cad element. While that can be useful most of the time, it also can also be disorienting and counter productive. For example, I often pick an element and then look to the tool bar to find out what it's properties are, such as layer, color, linetype, etc. With the ribbon, by default, it changes context when you pick an element, loading the tool bars for editing the type of element selected. The result is all the properties tool bars disappear, which leaves you searching for the tab that has the element properties too bars.
I found that by changing a variable we can have the benefits of the contextual tabs of the ribbon without the disorientation that so many users experience. The variable is RIBBONSELECTCONTEXT=0. This setting stops the ribbon from changing it's tab content when you pick an element. For example, if you have the ribbon tab set to home and pick an element, the ribbon tab remains at the home tab, which includes the properties tool bars. At the same time, an additional contextual tab appears (highlighted in green) for the type of element selected, such as a feature line for example. Thus if you only wanted to view or edit the properties of the selected element, you would have those tools available since you were on the Home tab when you picked the element..the tab didn't change. However if you indeed wanted the contextual ribbon for the element, just pick the highlighted (green) tab and you then have all the editing tools available for that element. Once you are done with the edits, the ribbon switches back to the tab you had active before (i.e. the Home tab) selecting the element (the Home tab).
This to me is a way to benefit from the Ribbon without the disorientation that so many users find disruptive.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
