Civil 3D Forum
Civil 3D 2008 Service Pack 2 - Update
27 REPLIES 27
Message 1 of 28
525 Views, 27 Replies
The version of Civil 3D 2008 Service Pack 2 that was released Thursday
afternoon (East Coast Time) had problems with the install on some user
machines. We tracked down the problem to a custom action that was trying to
backup and restore the profiles for Civil 3D. If this error happened, the
installer had already updated the Microsoft install subsystem to say that
the service pack was installed. This notification would then block
subsequent attempts to reinstall the service pack. This error only happened
on some machines. If your install was completed without errors, no further
action is required.
The custom action was removed from the installer, and the service pack was
refreshed on the download site Friday afternoon. This new installer will NOT
backup or restore your profiles, so be sure to back up before applying the
service pack.
If you had an issue with the earlier version of the installer, you will have
to uninstall Civil 3D and reinstall before applying SP2. The new installer
will not fix the earlier install error.
We are sorry for the inconvenience that this has caused.
Peter Funk
Civil 3D Product Manager
Autodesk, Inc.
27 REPLIES 27
Message 2 of 28
davidokonewski8100
Thanks for the update Peter! Now to uninstall and reinstall.
Dave Okonewski
Element - Cad Manager
2008 sp1
3.19ghz Dual Xeon/2gb/XPsp2 twin DELL 228 wfp's
; "Inc." wrote in message
news:5757678@discussion.autodesk.com...
action is required.
service pack.
Peter Funk
Autodesk, Inc.
Message 3 of 28
thanks for the update.
just for the record. i installed it on about 40 machines yesterday and only ran into problems on 3 of them. i think this bug was only related to issues on only 1of those 3.
Message 4 of 28
Thanks Peter
Message 5 of 28
I was wondering, has anyone else encountered this? When I try to uninstall, I get a message that says:
The following problems were encountered which prevented AutoCAD Civil3D from updating successfully:
-Fata error during installation.
I'm assuming the fatal error has to do with the SP2 installation. I have tried 4 times to uninstall, and I'm definately clicking on uninstall, not repair/reinstall. When I try to remove SP2 it says "This patch is not applied to this product". So basically I can't uninstall either one. Has anyone else had this happen? What should I do?
Message 6 of 28
Peter Funk - Autodesk wrote:
> ... you will have to uninstall Civil 3D and reinstall
Will the authorization information be preserved?
Terry
Message 7 of 28
oktiv
The patch was applied successfully however the amount of fatal errors and unexpected program closures have increased.
Could this be related?
Continuing with the error reporting
also...
Peter, can you address licensing in regard to uninstalling the product.
Any suggestions how to minimize down time with the R/R of the product.
Message 8 of 28
Terry -
It should be. I've never had to reauthorize after a reinstall/repair.
I don't pretend to know how the authorization works, but I've always
been under the impression that it stores that information in a "hidden"
part of the hard drive.
Jason Hickey
Dell Precision M90, Intel Centrino Duo 2.0 GHz
4GB RAM, nVidia Quadro FX 3500 (512MB RAM)
Windows Vista Business, Civil 3D 2008, SP1
www.civil3d.com
Message 9 of 28
I suspect the Boot sector as I've found licencing available after a Format
C: and reinstall O/S and Land Desktop exercise.
Laurie Comerford
CADApps Australia
www.cadapps.com.au
www.civil3Dtools.com
"Jason Hickey" wrote in message
news:5758784@discussion.autodesk.com...
Terry -
Jason Hickey
www.civil3d.com
Message 10 of 28
I don't think you are supposed to tell everyone about this.. 😉
Message 11 of 28
I am getting consistent fatal errors while doing grading post SP2
installation.
Any suggestions?
Tom
Thomas A. McCrate, P.E.
937-848-8700 Voice
937-848-7870 Fax
wrote in message news:5758416@discussion.autodesk.com...
also...
Message 12 of 28
mlynskey
I have exactly this same problem. I tried to install the first SP2, which didn't install correctly. Now I need to reinstall the program to be able to then reinstall SP2 but I can't get the program uninstalled now! I get that same fatal error during uninstall. Does anyone have a solution?
Michael Lynskey
Message 13 of 28
> reinstall/repair.
Remove/Reinstall fixed things with no need to reauthorize.
Terry
Message 14 of 28
Ever since I installed the SP2, my program crashes about every hour or so - mostly with either zoom extents or when working with large xrefs. Autodesk really should do more testing before putting out a service pak and letting us install it only to be troubled with new and more serious issues.
Message 15 of 28
Matt.Anderson
Have you updated your video card driver?
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 16 of 28
Was this an issue for the Land Desktop SP2 as well? The reason I ask is I got the attached error message while installing the Land Desktop SP2. After the error the progress bar started going backwards like it was rolling back the service pack. However, after that Land Desktop says I have SP2 installed. But my error message had to do with profiles, so it sounded related to what you described with the original SP2 for Civil 3D.
Josh
Message 17 of 28
oktiv
do you get errors referencing profiles still?
Message 18 of 28
oktiv
i dont think its avideo driver issue as mine is crashing when i try to close the program, as well as other non pan zoom functions
Message 19 of 28
No, I haven't updated my video driver???? Was I supposed to??
Message 20 of 28
Ditto, cannot uninstall due to fatal error.
Rail Community
