Does anybody know if this issue.
Is fixed in SP1?
Getting each user to copy the files or reset their profile isn't enterprise friendly. Especially if you have 1000s of users. Also for Education the summer may be the only time they can upgrade/re-image. Multiple users is a fundamental concept of good software. Due to how large the autodesk products are and how many pre-reqs they require the summer period is the time when the move to 2014 to 2015 will happen.
It would be good if someone from Autodesk could offer an estimate for when a fix will be available.
I had a look though the registry and their a lot of paths to the profile of the user who installed the software. The paths should really contain %username% .
Also a notification system for service packs/fixes would be helpful.
The really strange thing is on a standalone PC (not on a domain) multiple users seems to be able to launch C3D 2015 x64 .
Do you use a mixture of roaming and local profiles?
I know roaming profiles are not supported by Autodesk but the issue does'nt seem to occur.
These registry keys seem to keep the records of users.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\14A901DEE0AFB8A45A508C3CA5FD14F5
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\3E487C5C1E3426D0E184344D7EED8CE6
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\B7F27C72E12F9D548B71635E6B6BC2B3
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R20.0\ACAD-E000:409\aecProfile\Macros
The last one has many paths into user profiles, should really be c:\users\%username%\appdata\roaming\autodesk\c3d\support .
There are string values called ROAMINGUSERFILESFOLDER and similar but no ones for local users.
Your Name
