Civil 3D Forum
Civil 2012 Draworder
2 REPLIES 2
frankp23
991 Views, 2 Replies
Has anyone had issues with the draworder command from the the toolbars and/or icons not working. I get this message:
Command:  Unknown command "AI_DRAWORDER".  Press F1 for help.
Command:  Unknown command "FRONT".  Press F1 for help.
FYI - I installed the new Suites Package containing Autodesk civil 3d and regular AutoCAD. In Autocad it works fine, but in Civil is does not work. I have read some post about it being a "dorder.arx file" issue, but I can not find the file in either locations for AutoCAD and AutoCAD Civil.
 Troy Moore, PE
AutoCAD Civil 2012
Troy Moore
Civil3D 2014
Windows 7 Pro, 64 bit
Intel Xeon E31225 @ 3.40Ghz
16 GB RAM
2 REPLIES 2
wfberry
in reply to: frankp23
I have no problems with any of them.
Bill
AlmasSuljevic
Hi Troy,
I also don't have any issues with any of DRAWORDER commands. Any chance you have custom CUI loaded. Can you try typing DR for draw order and see if that works? Check your CUI editor, look for draw order command and see what macro says. You should see something like this:
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
