Ann,
I'm not sure of this, but if you're DATA directory is located under Program
Files\Land Dektop install location, AND you do NOT have administrator
priviledges on your XP install, then that may be the problem (cannot write
to the settings in that directory). You can change the data directory
through the SDSK.DFM file, or get administrator rights - I think you'll need
them to modify SDSK.DFM anyway.
If that's not the problem, other things could be file or pathnames problems,
or too long. I recall there being a limit on the pathname length for the
DATA dir items, but I can't recall exatly what the limit is.
Also, Like Karl mentioned, you should be posting Land Desktop questions to
the "land-desktop" discussion group.
Hope that helps.
Mike
Autodesk, Inc.
Michael Rogerson
Product Design
"AnnW" wrote in message
news:18883489.1081875380162.JavaMail.javamailuser@localhost...
> First. Am I in the correct group? I didn't see Civil 2004 just 3D. If
Civil 2004 is a separate group, where is it?
> Windows XP home edition Ver. 5.1 non networked.
> I keep going to adjust pipeworks settings and getting messages that it
can't create or find the necessary files, especially with the node values.
I can create a new project, copy the tins, and have it work fine.
> I tried downloading the patch yesterday and it eliminated the serial
number. The software had to be completely uninstalled & reinstalled to
work.
> Does anyone have any ideas?
