There is nothing in the dialog box
Autodesk autocad civil 3d 2013 - Tool Pallet Fix is installed
The properties dialog box does not show the selected object properly.
as attached.
It shows blank, missing information
Need assistance
Solved by sunnychandhok. Go to Solution.
I use AutoCAD C3D French, and I think you must change the number of Selected objects, ( type OPTIONS----> in the tab SELECTION---> change the numbre) you must put 25000 or 30000.
Greetings.
The following link was able to resolve the issue
Issue:
To fix the Properties palette, reinstall AutoCAD via Programs and Features (Add or Remove Programs in Windows XP). A repair will not resolve the problem. If you wish to not have Autodesk A360, first uninstall it and Autodesk Sync (so they do not show in Programs and Features) before doing the reinstall of AutoCAD.
If the reinstall does not repair the Properties palette, then reinstall Autodesk A360. Uninstall both it and Autodesk Sync if they are listed in Programs and Features, and then install Autodesk 360 again. The installer file is called "AdSync.msi" and is located within the AutoCAD 2014 installation folder in C:\Autodesk under \x64\Components\Cloudsync. You may do a file search for it and run it from the search results window.
If the above doesn't repair the Properties palette, then uninstall AutoCAD and Autodesk A360, and then install AutoCAD again. If you do not want to have Autodesk A360, the setup.ini file must be edited before installing AutoCAD again. Here is a link to our Discussion Groups with the instructions:
